Old 11th May 2010, 02:49 PM
Headshot Headshot is offline
Default Steel Q's
Hi,
Looking at starting the chassis in the next few weeks, I have found this on Ebay
http://cgi.ebay.co.uk/HAYNES-ROADSTE...#ht_500wt_1182
It says 2mm wall thickness, Thought I needed 1.6mm?
Is it ok to use 2mm or will the weight/structural integrity change too much?
(May be a dumb question as my book hasn't arrived from Amazon yet
Cheers in advance
EDIT: Just noticed he is a forum member so i guess its OK
Old 11th May 2010, 02:53 PM
dogwood's Avatar
dogwood dogwood is offline
2mm is fine.
a lot of people are using 2mm, including me
The add you are showing is our own Handyandy.
It is an excellent way to buy your chassis.;
Saves all that hassle of getting the steel and cutting it to length.
Edited: just noticed you have just noticed.....
David.
Old 11th May 2010, 02:59 PM
Cheers for quick reply,
Have been having trouble finding 1.6mm off the shelf, can find 1.5mm and 2.0mm.
I am trying to decide on cutting myself or paying a bit more for someone else to do that part would save me having to manhandle 6m long pieces of steel something would get broken
Old 11th May 2010, 03:50 PM
Saves cutting
Saves Swearing
Saves on buying a decent cutting tool
Saves time
Saves Sanity
Saves Space
Add those up and weigh against the price of steel alone.
Old 11th May 2010, 04:27 PM
Coozer's Avatar
Coozer Coozer is offline
And, saves waste from wrong cuts and unusable cut offs.
Saves head scratching as all the lengths have the correct angles and are identified as such..
LG,
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 11th May 2010, 05:59 PM
Davey's Avatar
Davey Davey is offline
If like me you have a large workshop, a bandsaw, plenty of time and happen to be slightly masochistic in nature then buy the raw steel and cut it yourself. If on the other hand you are working in a domestic garage, don't own a bandsaw (or other cutting device), prefer to stay on the sensible side of the sane/insane line then buy a chassis kit from Andy .
D.
Old 11th May 2010, 06:38 PM
Smile Welcome to the forum
A very warm welcome to the forum Headshot
Steel has gone up quite a bit over the last year .... The last quote I had for just the chassis tubes was £149 + £10 delivery ( Full uncut length prices ), that was at the end of last summer, daresay it has gone up even more since then
Started by using the bandsaw but soon got bored spending ages constantly changing the angle of the cut .... Ended up cutting the tubes square & cutting most of the angles with a hacksaw.
One thing is for definate.
If I were to start again, it would opt for the flat pack chassis route.
Understandably, you may wish to enjoy the challenge of cutting the steel from scratch .... On the other hand, you may be just like me & dagging to get on with the fun part of the build
Old 11th May 2010, 07:00 PM
Enoch Enoch is offline
I bought mine from handyandy, best decision I made I reckon. It went together like a dream, only very minor fettling was required. It's good quality steel and you know it will be accurate. I reckon it saved a month of very boring work too.
You can see how it has turned out at www.deepfolly.co.uk
Best and all that,
Enoch
Old 11th May 2010, 07:55 PM
Thanks for the pointers guys
Been browsing your website's Enoch.... they are great
Old 11th May 2010, 08:29 PM
MightyMouth MightyMouth is offline
I can think of no compelling reason to cut your own steel with a chassis kit this cheap.
