Old 16th May 2010, 05:39 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Glad you got it going Good feeling init
so what was the problem? or did it just go this time? sometimes you gotta leave it be and try again the next day lets the engine/plugs dry out and the battery recover
Ray
oh yes the ecu needs to know what cycle the engine is on tdc is not enough unless its wasted spark you should find a sensor on the cam or on a cossie its in the distibutor for instance
personally know nothing about bmw v8s but all engines need the same basic things
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 16th May 2010, 08:11 PM
my guess is dirty plugs
Old 16th May 2010, 10:33 PM
aerosam's Avatar
aerosam aerosam is offline
Spot on TT!
I only took 1 out when I was checking for sparks, when I removed the other 7, 5 of them were severely crudded up. It still didn't go straight away, but after cranking it then leaving it for a while several times over, first 1 cylinder would fire, then 2 then 3, and when i got 4 it just went!
Yeah, still DEAD CHUFFED.
Old 16th May 2010, 10:37 PM
aerosam's Avatar
Ray
Crackin feeling Ray, absolutely brilliant.
it has a cam position sensor on the drivers side inlet cam, i'm guessing that's it?
There's a vid on my blog, click below!
Old 16th May 2010, 10:40 PM
that sounds like it's gona scare the local cats, and the ones in the next county too!!!
Old 17th May 2010, 08:36 AM
Cool Awesome
That engine sounds awesome Sam
Definately going to be singing a sweet song once the silencers are fitted
No finer sound than a V8 purring away
