Hi am going to weld a steel floor but not sure of thickess can any one advise
Personally im going to use 2mm and weld it in.
My floor is thick, it doesn't have a clue what day it is let alone what 2 and 2 are...makes me wonder sometimes it really does...
i'd say 2mm ali, or 1.6mm steel, but it upto you
I've a 2mm steel floor, mainly because I had the sheet just sitting there!!
J |
mine is 2mm ali chequerplate - because it's what i had lying around.
I'm sure you are already aware of this, but isn't a 2mm steel floor going to be REALLY heavy?
Check out my Build Blog www.samsv8locost.blogspot.com And here's all my build photo's on a picasa web album http://tinyurl.com/5tbtm46 |
Rather than start a new thread I thought i'd bump this one up.
My question - I'll be using 2mm thick Ali for my floor but the supplier gave me a choice of grades - what do i want?!!! 1050, 5083 - these numbers mean nothing to me....Cheers! Josh |
Josh,
I am no expert but I have found thiswhich might be worth a read, Someone with more experience will be along in a minute. Cheers Ginge
Sent from my iPad, from who knows where in the world I was building but I am not now! Build Pictures Build Thread |
5083 is much better. Try and get a decent hardened one as well, T25 or something.
Blackburns Metals down in Edenbridge say they would recomend and can supply me with a 2m*1m*2mm thick ali sheet of grade 5251-H22. Can anyone in the know say if this is what I want?! Cheers
