Old 30th May 2010, 11:47 AM
tkpm tkpm is offline
Default Fitting Piston Rings
I have now got my piston rings, which way up do they go.
The top ring has no markings, but the middle ring has a small punch mark one side and the other side has a chamfered on the inner edge.
Terry
Old 30th May 2010, 09:02 PM
allterrain's Avatar
allterrain allterrain is offline
Hi,Most ring sets normaly have fitting instructions with them ,but Dot to top,Dont forget to clean carbon out of grooves with a broken old ring, and check ring end gap, 3 thou per inch dia of bore.Sit ring in least worn part of bore and measure with suitable size feeler guage before fitting to piston. Cheers Brendan
