Old 30th May 2010, 05:32 PM
Airhead's Avatar
Airhead Airhead is offline
Aha - Mark! Yep you are both welcome over - Bonzo what a small world; the inlaws live in St Hilary!
Matt
Ther's no place like 127.0.0.1
My build diary. http://www.mx5-locost.co.uk
Old 30th May 2010, 05:39 PM
Matt
Tis indeed a small world
I hope you enjoy your build
Old 31st May 2010, 12:04 AM
Airhead's Avatar
A picture or two of how things are looking:
And the partially complete framehead:
Old 31st May 2010, 12:09 AM
nice pics
there,s nothing wrong with those cuts at all , especially the 74degree cut in BR8 & BR9
front frame looks very nice too..
ps..... i,m intrigued with your signature "there,s no place like " what is it?
Old 31st May 2010, 09:11 AM
Headshot Headshot is offline
its a geek thing
http://what-is-what.com/what_is/127.0.0.1.html
Google is your friend
And I hope beyond hope my cuts are that good!
Failed builder
Old 31st May 2010, 10:54 AM
Airhead's Avatar
Thanks for the positive input.
I sent you a mail or the such Andy which I guess you didn't recieve 'cos it had the explaination to the 127 thing; the link above is technically correct but you need to take it one step further - as the loopback address or the address of the local machine it could be loosely defined as "home"...
Right - off to finish the framehead and get the chassis into 3 dimentions...
Old 2nd June 2010, 06:31 PM
Hoybi's Avatar
Hoybi Hoybi is offline
Default build the chassis step by step
Hello Airhead,
Unless you buy the good flat pack, you better cut the tubes when you need them.
Start off with a truly flat table and take your time to draw the plan as good as you can. Then you start building. Once the general structure is there, the tolerances are "self explaining". Too long and it won't fit, too short and it's not possible to weld.
Good luck with your build.
Eddy
www.alfaprojects.be
