Old 10th June 2010, 07:32 PM
David_17's Avatar
David_17 David_17 is offline
Already sent him one
Old 11th June 2010, 06:44 PM
David_17's Avatar
For those of you who like pics, look what arrived today
Old 11th June 2010, 07:18 PM
tkpm tkpm is offline
It's nice when stuff starts turning up, it's like christmas
Terry
Old 11th June 2010, 07:20 PM
You might want to get your self a fan to blow the smoke out of the container when you start welding and grinding.
Terry
Old 11th June 2010, 07:29 PM
Well done David,
just think there's going to be a car growing in that container soon......
Also had to reply since i was on 666 posts and can't be having that.
AndyH
Old 20th June 2010, 07:36 PM
David_17's Avatar
Default **Update Time**
Just a small update from the last few days.
Got some wood, built the table, got the chasis kit. All so far so good...
Got some scrap 2mm plate to practice my welding, after 2 days of trying, the welder won't penetrate.. I assumed it was because i was running it off a generator, so took it home to have a try on the mains - still the same. So just to double check, tried my Dad's gassless 100A cheapo mig, and it worked straight away.
Turns out with a bit of help from the mig welding forum, my new welder's got a blown diode, so it's only running half power
So my build is now at a stand still until i can get the front frame welded.
As it stands...
Old 3rd July 2010, 07:57 PM
David_17's Avatar
Default Just a little update
Still waiting to get the welder back from being repaired, so i've started cutting the wishbones and making jigs.
Also, my 2.0 zetec arrived yesterday Do most people fit an escort sump?? (as the mondeo one doesn't line up with gearbox bolt holes, also is too big for the starter motor)
Old 6th July 2010, 07:57 PM
David_17's Avatar
I've made a build blog that will be updated regularly.
It's located here... http://davesroadster.blogspot.com/
