Old 15th June 2010, 11:10 AM
Default Scuttle placement?
Can someone just confirm for me that the front edge of the scuttle goes where the top chassis rails start to taper in? I only have the scuttle at the moment, so I can't mock it all up to see!
Adrian
Old 15th June 2010, 11:18 AM
Hi Adrian,
Yes if you place the start of the scuttle at the front edge of U3 and U6 this will be just right. You may need to push the sides in slightly but this is normal as the can relax slightly after it comes out of the mold.
Regards....AndyH
Old 15th June 2010, 11:55 AM
Cheers Andy, going to need the bonnet and nose cone soon!
Adrian
Old 15th June 2010, 12:46 PM
Josh's Avatar
Josh Josh is offline
I was wondering about pushing the sides in, good to know it's not just me! What method of attachment should I use to fix the scuttle? Does it need to be removable?
Thanks
Josh
Old 15th June 2010, 01:10 PM
mark mark is offline
I used rivnuts just incase i wanted to remove it, just as well coz i took it off about 3 times before iva messing about with things!
Dont forget if you are using fibeglass panels they will add a little thickness on the sides too. You dont want to attach the scuttle flush with the chassis rails before fitting the sides as you will end up with a small step where they meet
