Old 21st June 2010, 11:41 PM
John Marchant John Marchant is offline
Default Cry for help - Welding
Is there anyone in the Newhaven, Sussex area that can help show me where I am going wrong with welding? Free beer and anything that I can help with in return. I am mig welding with argolite gas and getting it right (I think) some of the time but not sure. Really wish I had bought a chassis
Any help gratefully received........
Old 22nd June 2010, 02:22 AM
Post a few pics of what you have done and what MIG,wire and gas pressure your using and it maybe clear why your not getting the results you want.
Old 22nd June 2010, 01:19 PM
Marcus Marcus is offline
If you have a gas/no gas welder, it's worth checking the polarity of the torch as it's different for the different modes. We spent ages with our SIP welder making pigeon shit welds until we realised!!
Old 22nd June 2010, 02:03 PM
Firstly i would get a copy of CKC,april edition i think had a good article from AshG on mig welding.
As mentioned make sure you have the earth clamp and torch polarity correct as it is opposite to using flux core wire.
Dont be afraid to try different power settings and gas flow rates.My mig is a 200 amp but only has 4 settings,i have found that the 2nd setting is best on the chassis with a gas flow rate of 10l/min as im indoors in my shed.
The best thing to do obviously is just practice on some box section not straight on the chassis.Once you get it right it will sound like bacon sizzling in a frying pan .Strange i know but when it happens you will know.
Old 22nd June 2010, 03:38 PM
axle's Avatar
axle axle is offline
Sorry mate No where near you I am in scotland, but read the book and the your welder manual. Wear welding gloves and try holding the back of the welding torch with your left hand to make the correct angle.
Hope this is of some help.
Good luck
Regards Axle
Old 22nd June 2010, 05:14 PM
One of the best things you can do John is to get a good quality auto helmet so that you can see the weld pool as you are welding keeping the spark within the weld pool going in a "U" shape along the joint - effectively pushing the pool along with the spark. Keep the gaps between cuts as tight as possible until you get the hang of the way the weld pool behaves.
Turn up the power to as much as you can get away with and the gas flow at about 10 l/min. Also make sure your wire feed is as smooth as possible as this will make for a better more controllable weld.
Practice.....AndyH.....
Old 22nd June 2010, 10:36 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, just a thought what is argolite? not heard of it myself.
does it have any co2 in it if not youll never get a good weld on steel.
for steel you need an active gas (something with co2 in),if you use a non actve gas (pure argon or not enough co2) your welds will be porous and have loads of pin holes in them.
hope this helps Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 2nd July 2010, 10:17 PM
Sorry it was argo shioeld from BOC argon and Co2 mix.
Thanks to all for help and advice but may have to give up on the project for now as I just have too much onmy plate at the moment.
Old 2nd July 2010, 10:22 PM
james3004's Avatar
I found argonsheild universal a little better than argonsheild light, not that that really helps
--- James ---
IVA passed 20 June 2017
Flickr Album
