Old 19th June 2010, 12:07 AM
Well, they are so rare that if you need carb parts your gona search for a while..
Will be plenty powerful enough as a start, and less fitting issues than the EFI..
Old 19th June 2010, 12:10 AM
Seats look WAY WIDE!
Old 19th June 2010, 10:31 AM
Twin's Avatar
Twin Twin is offline
what's the max they can be please?
Twin
CSF £857.19
Twins Roadster
Old 19th June 2010, 02:18 PM
I think from memory the max width is about 440mm
Old 19th June 2010, 06:09 PM
I measure 451.5 between the inner faces of the side rail and tunnel rail on My Cad version.
Old 19th June 2010, 07:30 PM
Twin's Avatar
Thanks guys, i'll ask the bloke i'm getting them off to measure up
Twin
CSF £857.19
Twins Roadster
Old 22nd June 2010, 12:07 AM
Twin's Avatar
He says they are 430mm at the base, but I think I may have a MT75 box that may make em to big
Twin
CSF £857.19
Twins Roadster
Old 23rd June 2010, 12:12 AM
Nope, the width of the tunnel is the same with MT-75. It's just the part around the bell housing which is wider. 43 cm sounds ideal.
Old 23rd June 2010, 01:27 AM
Twin's Avatar
He smiles again
Twin
CSF £857.19
Twins Roadster
Old 19th August 2010, 12:37 PM
are teh elise seats going to fit?
