Old 15th June 2010, 09:30 PM
tonyhayden tonyhayden is offline
Default riv nuts
Hi All, Has anyone got a decent site for riv nuts and the applicator tool.
Cheers, Tony.
www.flickr.com/photos/tonyh3
Old 15th June 2010, 09:38 PM
These tools are excellent from Memfast, they're not the cheapest or most expensive but are bloody good and quick to use. Had a cheaper alternative first and it was rubbish. They also sell M6 Rivnuts for 6p each or you can get flush fitting ones for a bit more.
Regards....AndyH
Old 22nd June 2010, 08:41 PM
Mistrale Mistrale is offline
Hi there,
I bought the riv nuts from memfast on ebay! I made a too myself: I got a bolt of the appropriate size, 2 nuts and a washer. I drilled 1 nut out to remove the thread. I then threaded the bolt in the following order: Good nut, washer, drilled nut then rivnut. I popped the rivnut into the hole. I held the bolt still and turned the good nut 3 or 4 revolutions, which worked really well. The only slight mod I made was to hold the drilled nut still with a flat spanner - this stopped and turning of the rivnut. Worked a treat for me, much better than £37 for the proper tool!
see the results on my blog!
Old 22nd June 2010, 11:09 PM
tkpm tkpm is offline
What blog is that?
Old 23rd June 2010, 12:29 AM
Twin's Avatar
Twin Twin is offline
A picture paints a thousand words
Twin
CSF £857.19
Twins Roadster
Old 23rd June 2010, 06:20 PM
Blog is www.mistrale.blogspot.com
will dig out my homemade tool and take a pic - it just looks like nuts on a bolt though!
Old 17th September 2010, 04:47 PM
james3004's Avatar
What sizes of rivnut / nutsert do you need for the build?
I'm thinkin of buying one of the memfast tools but don't know what size inserts to buy?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 18th September 2010, 08:51 AM
Enoch Enoch is offline
I used nearly all 6mm. I bought packs of 3, 4 5 and 6, only place I have anything other than 6mm is for the fuse holders and the CO adjust where I used 4mm.
Enoch
