Old 11th July 2010, 03:52 PM
vincenzo vincenzo is offline
Default Max Radiator size?
Have got hold of a Clio rad with fan attached...but I'm not sure of the maximum dimensions as it seems fairly large. The overall width is 575mm including hoze inlets/outlet and the height is 445mm...how big are yours?? Can I use it?
Vince
Old 11th July 2010, 04:11 PM
Eternal Eternal is offline
ohh good idea would be fantastic to know what the max size is. Will need load of cooling on my one and have decided to go for a ally radiator that is extra thick.
Skyline Roadster
Old 11th July 2010, 05:21 PM
dan_g8 dan_g8 is offline
i think that the clio rad is the maximum size you can use if your using the saturn nose cone.
Old 11th July 2010, 05:50 PM
Remember size is not the only consideration. The location of the inlet and outlets and if they foul the chassis rails is a major consideration.
