Old 24th July 2010, 09:16 AM
Eternal Eternal is offline
The rear calipers,hubs and carrirers ect can be used and are the same as the sierra ones i presume? or have i just gone and bought completely the wrong thing? hah
Skyline Roadster
Old 24th July 2010, 09:35 AM
Should fit fine, they are slightly different but it should not make any difference.
They will be vented disk which was only ever the case on the 4x4 Cosworth Sierras.
Old 24th July 2010, 09:37 AM
Scorpio and Cosworth 4x4 use same rear disks.
Old 24th July 2010, 10:36 AM
Got the original diff i found as well as listed as ford 7.5inch lsd. For £120 but did a offer for £100 that was accepted and its in Poole so only 15min drive. Think that is a ok price or should i have haggled a bit more?
Add text@
"1992 GRANADA 7.5"LSD GOOD WORKING CONDITION WAS BEING USED UNTIL RECENTLY WHEN FAILED MOT
DIFF TAG READS 91 GG ADA 3.64"
checking on locostbuilders found this
Diffs:
Sierra 1987-1993:
91GG 4006 ABA - AXLE ASY-RR LWHD & B 3.91 Sierra/Granada/Scorpio LSD typ 2
91GG 4006 GA - AXLE ASY-RR LWHD & B 3.91 Sierra/Granada/Scorpio typ 2
91GG 4006 AAA - AXLE ASY-RR LWHD & B 3.36 Sierra/Granada/Scorpio LSD typ 2
85GG 4006 DC - AXLE ASY-RR LWHD & B 3.92 Sierra/Granada/Scorpio typ 2
V87BG 4006 BAA/CAA/DAA - AXLE ASY-RR LWHD & B 3.62 Sierra/Granada/Scorpio LSD typ 2
V86BB 4006 AAA - AXLE ASY - RR LWHD & B RATIO 3.64 Sierra Cosworth LSD typ2
Sierra 1982-1986:
V87BG 4006 BAA - AXLE ASY-RR LWHD & B 3.62 Sierra/Granada/Scorpio LSD typ 2
Granada/Scorpio 1985-1992
85GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2
85GG 4006 AAA - AXLE ASY-RR LWHD & B 3.36 Sierra/Granada/Scorpio LSD typ2
91GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Sierra LSD (Cosworth) typ2
91GG 4006 ADA - AXLE ASY-RR LWHD & B 3.64 64 Granada/Scorpio LSD (Cosworth) typ2
Granada/Scorpio 1992-1994
86GG 4006 AAA - AXLE ASY-RR LWHD & B 3.92 Sierra/Granada/Scorpio LSD typ 2
91GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ 2
Scorpio 1994 – 1998
95GG 4006 AAA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio LSD typ2
95GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2
96GG 4006 CA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio typ2 different mounting bracket (koala)
96GG 4006 BAA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio LSD different mounting bracket (koala)
96GG 4006 DA - AXLE ASY-RR LWHD & B 4.27 Granada/Scorpio typ2 different mounting bracket (koala)
96GG 4006 BCA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2 different mounting bracket (koala)
96GG 4006 BDA - AXLE ASY-RR LWHD & B 3.36 Granada/Scorpio LSD typ2 different mounting bracket (koala)
95GG 4006 AA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio typ2
95GG 4006 JA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio typ2
95GG 4006 LA - AXLE ASY-RR LWHD & B 4.27 Granada/Scorpio typ2
soooo got the right diff and can use all the rest of the stuff. Fantastic
thanks everyone for advice!
Skyline Roadster
Old 24th July 2010, 10:40 AM
£120!!! You Lucky B£$%^£$
Old 24th July 2010, 10:45 AM
Buy it now was 120.. i made a offer for 100 that was accepted.
Skyline Roadster
Old 24th July 2010, 11:28 PM
Right picked up the diff. It is a lsd and its fantastic! but huge heh
Just had a look at the brackets and well think im going to have to make the top a bit wider. What do you guys think?
Also the guy have a few more so if anyone wants his number give me a msg and i will forward it to you.
Skyline Roadster
Old 25th July 2010, 08:46 AM
Well in sierra lands theres 3 ways.
1) Swap to 7.5" Beam
2) cut the lug on the diff down.
3) cut and shut the top mount on the beam.
1) is out, 2) devalues the diff
so I recon you cut and shut the mounting dracket and make it a bit wider
Old 25th July 2010, 09:22 AM
indeed was thinking of getting another plate and widening it a bit for the top. Will take measurements ect and make a new threat about it. As i belive it would be quite handy for people to know. I really dont want to have to cut into the diff
Skyline Roadster
Old 25th July 2010, 03:45 PM
no nead for threats!!!
