Old 29th July 2010, 08:00 AM
Enoch Enoch is offline
Hi Al, we have access to the gear but the IVA test means we can't use it. The daft thing is that after the test we can do pretty much what we like. As far as the dash is concerned anything that is more than 127mm from the centre of the steering wheel has to have rounded edges or be sunk in to a padded dash. Toggle switches are out altogether - it makes it impossible to recreate authentic replica dashes for things like Cobras and Jag e types. We do get a much easier test than people in many other countries though so we can't complain too much.
Enoch
Old 9th August 2010, 07:12 PM
eSteve's Avatar
eSteve eSteve is offline
Default First post updated - ver 5
Update 5 done.
Thanks for the updates.
They've now all been included in the first post of this thread.
Spikehaus, car.mad, aerosam, David_17 and raceral, I've checked your links but could you check them aswell, I may have got some mixed-up.
Remember ?? indicates information we don't have, if you know what it should be let me know and I'll add it.
eSteve
Regards,
eSteve
Old 9th August 2010, 08:51 PM
raceral raceral is offline
I clicked on my build diaries link and it took me to the webshots site where my photos are located, but it opened on the dashboard photo well into the build and not at the beginning of the build.
The link that follows my signature at the bottom of this post would take one to the beginning of my build.
Al
1969 Amx
2004 Passat 1.8T 5Spd 4Motion
Haynes Modified Super 7 3.4L V6
www.lotussuper7replica.com/
Old 9th August 2010, 09:11 PM
Mine is ok, apart from I did not provide details of the transmission, I am using
Ford Type 9 - Heavy Duty Close Ratio Box with Limited Slip Diff
Old 10th August 2010, 01:35 PM
aerosam's Avatar
aerosam aerosam is offline
mine works fine, but I didn't add the gearbox, I'm using the original BMW donor's one. It's a Borg Warner box, that's all i know.
Old 10th August 2010, 07:03 PM
eSteve's Avatar
Default Will make another update in a day or so...
Thanks,
I will make another update with the corrections and additional information in a day or so...
Regards,
eSteve
Old 10th August 2010, 10:32 PM
gaz05 gaz05 is offline
I've started a build blog. It should be in my sig but if not it can be found here.
http://garyshaynesbuild.blogspot.com/
Hopefully I'll update regularly.
Total cost so far
Materials £3,150
Tools £855
Old 15th August 2010, 02:03 AM
Al
Call me slow I just figured out the question marks, I think.
GM 3.4 V6 + BW WC
1969 Amx
Old 19th August 2010, 08:35 PM
james3004's Avatar
I've now put all my pics on photobucket (link below) so probably won't use blogger anymore if you want to up date it
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 18th October 2010, 10:13 PM
Twin's Avatar
Twin Twin is offline
Hi folks, I now have a blog running in my sig
Could it be added to post #1 please
It's a 2lt twincam carbs, MT75 box
Twin
CSF £857.19
Twins Roadster
