Old 30th July 2010, 09:06 PM
Ricky Ricky is offline
Default windscreen help ?
hi i wanted to know if anyone can PLEASE!!! help me i just wanted to know does anyone know the length and hight of a full size windscreen if anyone could please help me with this info it would really be appreciated
Old 31st July 2010, 09:03 PM
Question windsreen help
anyone please?
Old 31st July 2010, 09:21 PM
Question windscreen help ?
hi thank you for the info but if you could check if your book gives any info on the windscreen and if you could give me that info it would be nice when you can that is thanks
Old 31st July 2010, 09:26 PM
or if anyone has a drawing of a full windscreen that they could give me that would be nice
Old 31st July 2010, 10:37 PM
David_17's Avatar
David_17 David_17 is offline
I'm sure there's one in the book, but i haven't got it with me (it's at my lockup) so can't check for you.
*updated 7/6/11*
Old 1st August 2010, 08:46 AM
dogwood's Avatar
dogwood dogwood is offline
Hi Ricky;
I don't think anyone has actually put a screen on the Roadster yet.
Erm......
I've no idea what size I made it not though , sorry.
Just made it up to suit my build...
David.
Old 1st August 2010, 10:24 AM
A few things to consider when making a screen as I've thought about making screens for the roadster but glass does'nt travel well with couriers!
How tall are you while sat in your seat?
Have you allowed enough space early enough in your build around the scuttle to fit the wipper motor and demister assembly?
What angle do you need it to be at to get in with out hitting the frame every time?
It would seem that the screan is pretty much a custom part and some thing that will need making to your own design. The one thing I would say is if you intend to put side screens on,either fit a fine nylon mesh or polycarbonate screen behind you on the roll bar.It cuts down all the vertex effect that comes in from behind and makes for a more civalised drive.
Old 1st August 2010, 11:52 AM
Is there an IVA/test for builds of this nature in SA and if so what do the regs say about w/screen's.
Old 1st August 2010, 07:39 PM
hi everyone thanks for all the info and what you all have said it makes sense . And im not to sure what the iva/road worthy test say about it i need to find out about it and does anyone know what is that black strip between the scuttle and the frame of the windscreen . Once again thanks everyone for the helpfull info
Old 1st August 2010, 07:42 PM
this is a first for me so im not to sure as well on how you go about the regs for a iva/road worthy test so i need to go to them and get more info on it
