Old 2nd August 2010, 10:46 AM
Enoch Enoch is offline
Default Front Camber Adjust Nut
Hi there, what have you guys done re covering the front camber adjust nut for the IVA test? I can't find anything that I think the inspector will be happy with
Any ideas welcome.
Enoch
Old 2nd August 2010, 11:18 AM
Qwerty9 Qwerty9 is offline
Enoch,
What about these,
http://www.saturnsportscars.co.uk/st...d&productId=67
Cheers,
Andrew
Some large diameter cable heat shrink should do fine Dave
Old 2nd August 2010, 11:22 AM
Originally Posted by Qwerty9 View Post
Enoch,
What about these,
Cheers,
Andrew
We posted at the same time Andrew, you still need the lock nut on the outside to use the adjusters though. Heat shrink worked fine for me and others i know that have gone through. Something like this:
http://www.audiospares.com/product.p...2&cat=0&page=1
AndyH
Old 2nd August 2010, 11:23 AM
Thanks Spud, I thought Ash found out that heatshrink was not permitted any more?
I am thinking of speaking to my local test station and asking a few direct questions to try and elliminate some of the variances.
Thanks again,
Enoch
Old 2nd August 2010, 11:29 AM
I think Ash just had a very pedantic tester, as far as i'm aware heat shrink is fine but if you're not sure cable glands can be used just need to get the correct size.
AndyH
Old 2nd August 2010, 11:41 AM
Thanks again Andy. I think I will try to speak to the IVA centre and see if they are equally pedantic when the build is not being covered by a national magazine
Best and all that.
Enoch
Old 2nd August 2010, 06:49 PM
Spud69
Jumped in without reading properly, have since read and realised my mistake.
