Old 5th August 2010, 09:37 AM
Jeze2903's Avatar
Jeze2903 Jeze2903 is offline
Default Radiator hoses
Having trouble with finding a suitable route for the lower radiator-engine hose on my 1.8 CVH engine. Does anyone have any pics??
Old 5th August 2010, 07:40 PM
I haven,t got any photos of the lower hose route but I can take some tomorrow morning if that helps ?
I forgot to ask....which Rad are you using?
Old 5th August 2010, 08:17 PM
Jeze2903's Avatar
Hi, I'm using a Clio rad, and already routed the hose up over the chassis rails but I think it's too high as water doesn't circulate.
If you could take a pic that would be great
Old 5th August 2010, 08:31 PM
I,m using a Polo rad, so not sure what the inlet/outlet positions are on a clio rad, but I,ll take some pics in the morning & post up on here.
May i ask, what have you done with the heater hose connections? have you looped them in the return flow direction? just trying to work out why yours isn,t circulating etc.
Old 5th August 2010, 09:04 PM
Jeze2903's Avatar
Hi Andy, Ive looped the heater hose from the auto choke to the tee with the bottom hose connection on the L/H side of the engine, if that makes sense. The water flows through this pipe fine, but not through the rad
Old 5th August 2010, 09:16 PM
Yep, makes sense as thats how I did mine too
hmmm , no idea why its not flowing thru the rad either
I,ll post the pics tomorrow, see if that helps in some little way.
Andy, I've got a polo rad, but it's totally bare, any chance you could get a few pics of yours, uncluding the thermostat housing
Sean
Old 5th August 2010, 09:25 PM
sure no prob
ps... what do you mean "its totally bare" ?
Old 5th August 2010, 09:34 PM
sure no prob
No thermostat or thermostat housing, just want to see what parts I need to order up. Sorry, should have been clearer
Sean
Old 5th August 2010, 09:50 PM
Sean..... you have a PM
