Old 11th August 2010, 10:52 AM
davidimurray's Avatar
Default Sierra Flasher Relays
Stupid question - where does it nornally live? Is it on the column under the steering cowl? I cannot for the life of me remember where mine was and I'm not brave enough to drag the loom out of the bin bag it is living in to find out
Old 11th August 2010, 11:06 AM
Correct David, Red flasher relay is to be found hiding under the steering column shroud
Lost count of the number of Sierras I have seen at the breakers & found that someone has ripped the shroud apart just to get at the flasher relay
Guess they don't know just how valuable those shrouds are getting
Old 11th August 2010, 11:38 AM
Cheers Ronnie
I'm just doing some extra info to go with the wiring diagrams so will add tha in.
