Well, they are so rare that if you need carb parts your gona search for a while..
Will be plenty powerful enough as a start, and less fitting issues than the EFI.. TT
Seats look WAY WIDE!
what's the max they can be please?
I think from memory the max width is about 440mm
I measure 451.5 between the inner faces of the side rail and tunnel rail on My Cad version.
Thanks guys, i'll ask the bloke i'm getting them off to measure up
He says they are 430mm at the base, but I think I may have a MT75 box that may make em to big
#18
Nope, the width of the tunnel is the same with MT-75. It's just the part around the bell housing which is wider. 43 cm sounds ideal.
#19
He smiles again
#20
are teh elise seats going to fit?
