Old 22nd August 2010, 05:13 PM
frankieboy's Avatar
frankieboy frankieboy is offline
Default Sierra Sapphire 1.8cvh Auto Doner
Hi , ive been offered a Sapphire 1.8cvh Auto would this be any good as a donor. Oviously i would have to source a manual box,flywheel and clutch. Are the front hubs ,prop and rear diff the same as a manual??
Frank
Old 22nd August 2010, 08:14 PM
TT is the Ford guru Frank.
Old 22nd August 2010, 08:31 PM
diff is probably a low ratio, prop you will be shortening anyway ( or buying one )
rear drums & shaft will be fine.
engine will be fine .
uprights fine.
so just a type 9 to source realy.
Old 22nd August 2010, 10:17 PM
frankieboy's Avatar
uprights fine.
Cheers for the replys. That should be ok then, so it looks like i've got my donor car then. The diff will be ok for now , i can always change that later.
Frank
Old 22nd August 2010, 11:15 PM
will give gr8 Acceleration..
