Old 21st April 2008, 06:02 AM
Default Painting donor parts
Anyone have any favourite paints for painting donor parts? I'm not a massive fan of smoothrite, as I find it a bit brittle, and would also prefer a satin black finish. Any suggestions welcome!
Adrian
Old 21st April 2008, 07:46 AM
jabs jabs is offline
I've read this stuff is very good, if a little expensive
http://www.por15.com/?gclid=CMPUvPDG65ICFQW_1Aod8yng4A
http://www.frostmarine.co.uk/product...FQHD1AodwyiX4A
I'll be giving it a go when I comes round to painting my chassis
Old 24th May 2013, 03:52 PM
jps jps is offline
Ancient thread revivial warning!!!!
Chassis progress has stalled a bit - by brother-in-law is the welding man and he's busy at the moment...
So - i'm going to paint some donor parts: hubs / diff / gearbox / engine block / etc.
From a rusty lump dragged off a Sierra what's the process? I don't want to setup an electrolysis bath - and don't have ready access to a sandblaster - so will be going wirebrush / scotchbrite pads / wet'n'dry for the first stage.
But then what?
Some people mention cleaning down with thinners or petrol
Some people don't seem to use a primer, some use an etch primer, then another primer, then a top coat. And multiple coats of each step.
Some people go Hammerite on bare, or even rusty, metal?!
What do I need to do???!!!
Old 24th May 2013, 05:57 PM
I went at the parts with a wire brush attached to a drill and then ham merited all the parts.
Old 25th May 2013, 11:05 AM
I used the electrolysis method and a wire brush, don't know why you dont want to go down that route as it is the easiest by far
Old 30th May 2013, 05:59 PM
So far I've just degreased, used a wire brush and/ or abrasives where appropriate and then primed and painted with enamel.
i would be very interested to find out what's needed to set up electrolysis though.
Old 30th May 2013, 09:15 PM
All you need is a bucket, an old battery charger, water, a piece of scrap metal and some crystals but for the life of me I can't remember the name of the crystal but you get them from Tesco or Sainsbury's, mix it all together and you get magic
Old 30th May 2013, 09:20 PM
Just looked it up its washing crystals and attach the positive to the scap part and the negative to the part to be cleaned.
jps jps is offline
it's soda crystals, you find them in the cleaning aisle. I may well give it a go, but some of my bits are already reconditioned with only light surface rust, so putting them through electrolysis seems like overkill...
edit. cross posting! the ones I got from tesco were called soda crystals. took some finding though!
Old 30th May 2013, 09:26 PM
It really does work well, I wish I had taken a photo of my front hubs before i did them you would have thought I had got them out of a field but they came up like new.
