Old 4th September 2010, 10:19 PM
rapidtornado's Avatar
Default Mini One (new shape) seats
Got an opportunity to pick up a great set of carbon ray half leather Mini One front seat for a good price, anyone know if they would fit in the car?
I'm working on the principle that around 41-42cm is max width? if anyone could advise as I don't have my chassis constructed yet
Matt
Old 5th September 2010, 07:48 AM
455 i think ia the theoretical maximum. But idealy you want a little clearance.
Most production car seats are far too wide, most aftermarket ones too wide tooo.
Old 5th September 2010, 09:53 AM
Hi Matt
I have just had a quick measurement of my chassis & as TT has said, there is a gap of aproximately 455mm for the seats.
As TT has also said, you need to bear in mind that the harness fixings will need a little of that space.
430mm - 440 mm Max seat width ??
Old 5th September 2010, 09:56 AM
Thanks both, much appreciated, I'll be sure to check before I hand over the spondulics
Old 5th September 2010, 12:53 PM
Mazda MX-5 seats can be persuaded to fit into the Locost chassis (a bit narrower than Haynes): both foam and some of the pan has to be cut.
http://cheapsportscar.net/diary.php?UID=201
http://cheapsportscar.net/diary.php?UID=202
http://cheapsportscar.net/diary.php?UID=209
http://cheapsportscar.net/diary.php?UID=211
I have a pair of Honda CRX seats that could theoretically fit this way, the distance between the outermost hinges is around 450 mm, and the full width is over 500 mm unmodified. A lot of cutting would be required.
Old 5th September 2010, 04:35 PM
Good point, and, of course, the IVA examiner will insist on being able to see the bolt heads, so just because the seat fit in between there may still be a problem (unless the seat can be slid forward to allow inspection).
