Old 6th September 2010, 09:36 PM
james3004's Avatar
Default Sealant?
What is the best sealant to stick the ally panels on with?
I found this on ebay:
http://cgi.ebay.co.uk/SIKAFLEX-221-E...item23090ae728
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 6th September 2010, 09:46 PM
that is what I will be using.
Old 6th September 2010, 09:48 PM
David_17's Avatar
David_17 David_17 is offline
That's cheap. I bought tigerseal for my floor.
*updated 7/6/11*
Old 7th September 2010, 09:35 AM
Coozer's Avatar
Coozer Coozer is offline
Tiger Seal all round on mine.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 7th September 2010, 11:50 AM
I got a product called Omniseal from our local autofactors.
I think so long as it is a pu adhesive you should be fine.
Old 7th September 2010, 03:48 PM
Enoch Enoch is offline
I used that Polyflex, it's good stuff. Don't get it on your fingers though, it's a pig to get off
Old 7th September 2010, 05:15 PM
next Q.
Naked or painted rails?
Old 8th September 2010, 08:12 AM
locostkiwi locostkiwi is offline
im going to powercoat my chassis then use sealer im using "no more nails"
not too sure if you get that in UK.
Old 8th September 2010, 10:35 AM
you can get no more nails, but I have always found I had to use nails as the stuff never works.
Old 8th September 2010, 01:55 PM
tkpm tkpm is offline
No more Nails is meant for the house building industry, as it's not flexible enough, i would use Tiger seal or similar.
Terry
