Old 18th September 2010, 07:15 PM
shh120m's Avatar
shh120m shh120m is offline
Default sb5 and sb6
can someone please explain why sb5 and sb6 have compound angles? Can they be cut so they lay square against the seat back bracing?
thanks
nathan
Old 18th September 2010, 08:34 PM
THe compound angles on SB5 & 6 are due to the angle of the seatback top rail SB2.
It is not too easy to visualise looking at the drawing & becomes a lot clearer once you start constructing the seatback area.
Andy could probably explain it a bit better than me
Old 18th September 2010, 08:42 PM
shh120m's Avatar
ahh, just me being stupid, i was thinking that the two horizontal rails were paralell. Guess il have to cut them as the book intended. I HATE COMPOUND MITRE CUTS!!!!!!!!!
Old 18th September 2010, 08:48 PM
Unfortunately the top rail is paralel to the bottom chassis rail & the centre rail follows the angle of the seat back
SB5 & 6 are tricky little devils to cut .... Well they are if you are a senile old twit like me
Old 18th September 2010, 08:52 PM
No sympathy on here Ronnie,just good advice.
Senility ? no way mate.
Old 18th September 2010, 09:04 PM
You wouldn't say that if you saw me spending almost 2 days sitting on a stool, looking at a big box of bent pipes, thinking " How the hell am I going to make a manifold out of that "
Old 19th September 2010, 09:29 PM
Ahh SB5 & SB6
They are tricky little blighters indeed.
When cutting them, from the book diagram, ignore the sketch showing a 17degree angle.......this is the angle you create when cutting the compound angle.
hope this helps
