Old 25th August 2010, 02:12 PM
Thank's Daz
Now written in my build book
5k miles a year .... I struggle to do 1.5K miles per year in my daily driver
Pleased to hear you are making good progress
I guess it must be nearly time for me to request a VIN number from DVLA, time I got that stamped on the chassis.
Old 25th August 2010, 03:03 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Ronnie,
got vin, stamped in, in a couple of places.
Not that far off, need to alter front wing stays (didn't buy SSC Wings - sorry). So need to fettle to clear tyre.
Upload mega jolt map, rollling road session to set carbs up and all the sharp edge tripe to do. Nearly there but not rushing!!
Oh and must run it long enough to get fan to cut in?? Not convinced it will, but we'll see.
Daz...
Old 29th September 2010, 08:51 PM
Thanks for the "heads up" from this thread, I have arranged my insurance today, as its driveable & so making it "nickable" thought best to get it insured,
Fully comp
5k miles per year
agreed value
90 days euro cover ( don,t think i,ll be using that )
Parts only
cost = £95
Its the only vehicle I,ve had where it costs more to tax it for 6 months than it costs to insure it
Old 30th September 2010, 08:02 PM
mark mark is offline
Fully comp
5k miles per year
agreed value
Parts only
cost = £95
Being old has some advantages then!!!
You got yours a little cheaper than mine, not much though, maybe enough for a takeaway!
Old 30th September 2010, 08:08 PM
Ohhh, mine should work out about £12.50 in that case
Cheeky "whippasnappa"
Tho, yes Mark, you have a point
Old 30th September 2010, 08:17 PM
David_17's Avatar
David_17 David_17 is offline
Not looking forward to my quotes
*updated 7/6/11*
Old 30th September 2010, 08:24 PM
David_17's Avatar
Quick question, how many no-claims did you tell them you had? As i've been told your no claims is only for 1 car. Which means 0 no claims on the kit car insurance
*updated 7/6/11*
Old 30th September 2010, 08:36 PM
When I spoke to them they said that the NCB that I have on my "daily" drive vehicle wasn,t taken into consideration ( I have full NCB & clean license) ,
I suppose the home build/kit car industry in relation to insurance is totally different to "normal" vehicles, Tho it helped when I mentioned I was a member on this forum & LCB too.
So, £95 taking into account that no NCB was calculated into the quote is a very good deal indeed.
Old 1st October 2010, 12:50 AM
You can only use your NCB on 1 vehicle so may as well be your daily driver.The other option is to try and get a FLEET policy which will cover both cars under your NCB.Dunno if they still do that in UK though.
