Old 10th October 2010, 08:23 PM
Default Steering linkage help needed ?
Hi Guys,
I'm using a sierra steering linkage and as per book I need to extend it. I am intending use the sleeve method. Anyway I have been on the lookout for a suitable sleeve for ages but cant seem to find anything, there is a serious lack of steel stockholders in my area (Blackwood South Wales) or at least I cant find any suitable.
Could any body point me in the correct direction of the size needed, somewhere I could get it or if someone has any I could purchase it off them ?
Thanks in advance Dan.
Old 10th October 2010, 08:41 PM
Which coupling are you using at the rack end?
There is a thread discussing this very task, I,ll have a look & see if i can find it for you
Old 10th October 2010, 08:50 PM
Hi Andy,
The coupling is off a sierra xr 4x4 and correctly mates to the escort rack and sierra column, the problem is that it isnt long enough.
Old 10th October 2010, 08:59 PM
Have a look at this thread, see if it helps, I,ll keep looking to see if any other threads might help.
http://www.haynes.co.uk/forums/showt...mn+ex tension
If you get stuck, I might have some thick walled tube that i used on my car left over...
Old 10th October 2010, 09:11 PM
Thanks for that Andy,
The outside diameter of the link is 25mm so 3mm sounds strong enough to me. If you have anything like that knocking about I would be extremely greatful.
Old 10th October 2010, 09:20 PM
I,ll double check in the morning & get back to you ( car not being built at home).
There are a few different threads discussing the extension & how other builders have done it, have a look using the search button ( top of page), there are too many to put all the links here,
It all depends on how you intend to join the rack to the original column just before it enters CP16 ( mines done like in the photo of the attached linked thread)
Old 11th October 2010, 12:00 AM
Locky Locky is offline
there is a steel merchants on Gabalfa interchange roundabout in cardiff near the Heath hospital called Fromstock i think they used to be C G Rees they sell all sorts of metals and shapes too. http://www.fromstock.ltd.uk/
BTW this is not a plug as i have no relation with them only that ive used them in the past.
HTH
If it has breasts or wheels it will give you problems.
Planning Stage
Old 11th October 2010, 10:13 PM
sorry Dan, I checked my steel bits bin & sadly don,t have any of the tube I used left , I,d forgotten that I made it into part of my garage security, & its welded in place.
Sorry about that.
Old 13th October 2010, 07:30 PM
Smile
hi im in carmarthen and have been using dyfed steels in llanelli and ellis steel in swansea they stock most things, cheers
