Old 9th October 2010, 08:57 AM
Default Master cylinder fluid reservoir
Anyone else found their sierra reservoir hits the bulkhead?
Anyone got a spare fluid cap?
Old 11th October 2010, 07:35 PM
David_17's Avatar
David_17 David_17 is offline
Which bit hits the bulkhead?
Also, anyone know which pin is which on the wiring?
*updated 7/6/11*
Old 11th October 2010, 08:00 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Hi TT,
yes mine hits/very near to the bulkhead but it still fits ok and doesn't leak so I can't see it being a problem.
You could always shim it out a smidge, maybe i should of done that? I made my own rod to connect brake pedal and cylinder so could of easily adjusted. Maybe next time!!
Daz...
Old 11th October 2010, 08:22 PM
davidimurray's Avatar
Mine doesn't hit the bulkhead. I will get some pics next time I'm down the garage if it helps.
With regard to wiring if you clean the cap you can actually see the metal tracks through the plastic. I can check my wiring if it helps. From memory one track goes to earth, other goes to handbrake switch, third goes to warning light.
Old 12th October 2010, 10:30 AM
Think it depends which master cylinder you have TT, the bendix cylinder and res fit with plenty of clearance. You can still get the on e-bay for £20 odd ish quid.
David, i believe the fluid level indicator is a switched earth so it shouldn't matter which way round you put the wires.
Cheers...AndyH
