Old 18th October 2010, 07:51 PM
james3004's Avatar
Default fibreglass panel colour
I'm going to paint my roadster, so what colour fibreglass stuff would it be best to get?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 18th October 2010, 07:53 PM
David_17's Avatar
David_17 David_17 is offline
White will be the easiest to paint, why not get the fiberglass the colour you want though?
*updated 7/6/11*
Old 18th October 2010, 08:13 PM
james3004's Avatar
cos the colour i'm doing it is a pearlescent, and it won't match the painted ally if i get it pre coloured
--- James ---
Flickr Album
Old 18th October 2010, 08:15 PM
David_17's Avatar
Ah, you may have to check with the paint supplier then, as some pearlescent need a coloured base cote if i remember rightly.
*updated 7/6/11*
Old 18th October 2010, 08:33 PM
james3004's Avatar
they recomend a white primer, so i guess white it is
--- James ---
Flickr Album
Old 19th October 2010, 09:01 AM
You have to be careful when painting fibreglass parts. How are you intending to paint your parts ie outside, in the garage or in a heated paint booth/oven?
During the laminating process you get small air bubbles trapped between the layers which will expand when they get warm or in the case of a paint booth/oven hot. It is adviseable to pre heat the parts to cause the bubbles to expand before you prime the parts, this way you can fine fill all the blisters before they are painted so they don't break through your finished paint.
Also beware 2 pack hang overs if thats what you have in mind for home use they're a killer!
Old 19th October 2010, 09:45 AM
Locky Locky is offline
2 pack paints can be cyanide based so decent respiratory eqpt will be needed and not the paper mask
If it has breasts or wheels it will give you problems.
Planning Stage
Old 19th October 2010, 10:07 AM
I have had them sprayed using acrylic paint James with a lacquer finish over the top. For best results try a local body shop with a ventilated booth - i'm sure they wont be too expensive if you have all the parts available and they can spray them in one go.
The most important thing is to have a completely dust free environment as any impurities will show through the finish and a white gel coat finish will be fine with no need for a primer.
All the Best....AndyH
Old 19th October 2010, 06:45 PM
fabbyglass
Only true if the laminating isn't that clever in the first place...
Old 19th October 2010, 08:35 PM
james3004's Avatar
The paint I have in mind is single pack, haven't decided on the laquer yet.
What is the best sort of etch primer to use for the alli?
Ii have been told by several people that it tends to srape off easily with your nail?
I pan to paint in my garage as i haven't had bad results in there in the past
--- James ---
Flickr Album
