Old 7th October 2010, 06:42 PM
tkpm tkpm is offline
Default Headlight Bracket Measurement
Hi guys,
I know is has been covered before, but what is the lenght of the headlight bracket.
I did a search but couldn't find the thread.
Terry
Old 7th October 2010, 07:38 PM
squbti's Avatar
squbti squbti is offline
Hi, I think its different from car to car but maybe this can helpLighting-Front.jpg
Samy
Old 7th October 2010, 07:42 PM
David_17's Avatar
David_17 David_17 is offline
It depends on the size of your light, to the length of your bracket.
The measurement most people use is 120mm, for some reason i cut mine at 80mm and got away with it (as my lights are a slightly smaller diamater)
Hope that helps a little.
*updated 7/6/11*
Old 18th October 2010, 09:48 PM
carlknight1982's Avatar
is that 120mm from the center of the bolt mount hole or is that 120mm for just the "shaft" not the round bit with the bolt mount in.
Roadster No 2 build
Cost to Date : £93
Old 18th October 2010, 09:53 PM
I used 120mm from the center of the hole to the edge of the chassis just above the upper shock mounting bracket,mount the stalk on the side of the chassis rail as this way you don,t need to cut the nose cone , this then should give 90cm between the holes of both brackets.
Old 18th October 2010, 10:02 PM
Andy as always I could kiss ya!
Roadster No 2 build
Cost to Date : £93
Old 18th October 2010, 10:06 PM
runs screaming
Old 19th October 2010, 12:10 AM
Good job he is a few miles Andy !!!!
