Old 28th October 2010, 08:01 PM
shh120m's Avatar
shh120m shh120m is offline
Default anyone got some bolts for me?
Hi guys, went to fit my diff brackets and i forgot i ruined the long mounting bolts removing them from the donor axle assembly. I dont suppose anyones got any laying about spare for a few quid?
regards
nathan
Old 28th October 2010, 08:31 PM
David_17's Avatar
David_17 David_17 is offline
There should be a local fixings company that will supply new ones for a few quid somewhere near you.
*updated 7/6/11*
Old 28th October 2010, 10:00 PM
snapper snapper is offline
If you are really stuck you can use threaded bar
Old 29th October 2010, 10:23 AM
I've got a few spare you can have when you pick up your bits Nathan,
Bits i'm waiting for where apparently sent by Interparcel on the 23rd so should have been here by now. Just about to phone interparcel and try and locate them.
Cheers...AndyH
Just checked with Interparcel Nathan and it is stuck somewhere with UPS, they are trying to locate it. Shame they are normally very good
Old 29th October 2010, 11:14 AM
I use UPS via IP a fair bit and they are usualy fairly good.
Better than "HDNL" or "My Herpes"
Old 30th October 2010, 09:44 AM
I've used UPS a few times to Rob and they have always been okay but this ones coming from another supplier to me so i don't know how its been packaged. Usually use TNT for UK and Fed Ex for Europe, via Interparcel, and the only trouble i've had is when TNT put the wrong barcode on the wrong package, thats all they go by and not the address, so i always check they are on the right ones now. Interparcel sorted it out no problem though.
Oh Bugger......AndyH
Old 30th October 2010, 03:58 PM
shh120m's Avatar
cheers andy, bolts are great, just on with priming and painting all those shiny bits! cant wait to get bushes in, just got to wait for paint to dry so im twiddling my thumbs for a couple of hours.
nathan
