Old 19th November 2010, 09:01 PM
brainbug007's Avatar
Thanks for that alga, helps loads! Any idea roughly how much 33.7x2.6, 25, 19, and 3mm strip/plate I'll need?
Old 19th November 2010, 10:10 PM
shh120m's Avatar
shh120m shh120m is offline
I found it cheaper to buy chassis plates And brackets precut from Andy at Saturn, that way I didn't end up with tons of unneeded steel sheet. Also andys plates are laser cut so there spot on, there's no way to cut some of the plates with a hacksaw, believe me iv tried!
Old 19th November 2010, 11:38 PM
brainbug007, just do the math. 22 bushe tubes 35 mm each. That's 770 mm. So, 1 m should be enough and you should have some room for error.
3 mm strip? Frankly, I'm not sure how much of it you need. There are many parts out of 25x3, 30x3, 40x3 strip. There is no 3 mm strip available here, so I just got a 1000x1200 mm sheet and still have about half of it left.
As for the wishbone tubes, it's also easy to do the sums: 3.92 m of 25 and 2 m of 20. Also, it's wise to have some extra in case you don't get it right the first time.
Hacksaw? That's indeed hard. You need an angle grinder!
I got all the 10 and 5 mm plates laser cut, and some precise 3 mm plates: all of the rear upright parts, steering support. I also got all the suspension brackets laser cut and bent in an engineering shop. The rest of the plates are pretty easy to fabricate with an angle grinder. I'd say the hardest part is the larger holes: in the pedal box for the master cylinder, the bolt access holes in the rear damper mounts. Without the right instruments they are really tedious. Lots of drilling, filing, grinding and cursing.
Later I ended up buying another offcut of the 5 mm plate for the engine mounts.
