Ok - I admit it - I'm getting soft. Last year I battled on through the winter - even having a few days in the garage where the toilet, kettle etc was frozen solid - in fact the fridge was keeping the milk warm so it was the only thing not frozen.
The weather reports are showing plunging temps the next few weeks so I'm thinking I might have to bite the bullet and buy a heater. Anyone got any reccomendations ??? Looked at these - http://cgi.ebay.co.uk/2-Kw-Industrial-Heater-garage-workshop-electric-fan-/200538923031?pt=UK_Home_Garden_Hearing_Cooling_Air &hash=item2eb10d2017 Or there are some 3Kw versions around. Is electric the best to go for. The garage is a bigger than normal doubel, with full width steel roller shutter and tin roof.
Gallery 2 http://www.facebook.com/album.php?ai...4&l=a9831a9319 Gallery 3 http://www.facebook.com/album.php?ai...4&l=3f0d42c523 Gallery 4 http://www.facebook.com/album.php?ai...4&l=efb083b7df Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5 cd3a Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=1&l =fe779b358c |
You might find you will have to be close to it for any heat.
I run a commercial garage and its impossible to heat and usually warmer outside than in by 2/3 degrees. ![]()
Electric is an expensive way of heating any space and a large double garage with tin roof and double width metal door is going to be lousy at keeping the heat in. I'd put a ceiling in about four inches from the roof and insulate it, if you can manage to do something similar to your door you'll have a better chance of getting it warm and keeping it comfy.
Personally I'd opt for gas, either a radiant heater like this http://www.sealey.co.uk/PLPageBuilde...iredresults=16 or one of the Sealey type gas jet jobbys like this http://www.sealey.co.uk/PLPageBuilde...iredresults=16. The downside of the radiant one is it produces a very localised heat and might struggle to make the whole garage comfy, the other one is dearer but as it is basically a blown air heater it will distribute its heat better, obviously it is a lot dearer and they are quite noisy. D.
visit my website at www.cossie.davenewell.co.uk Last edited by Davey : 22nd November 2010 at 09:25 PM. |
I use a £10 3 bar halogen heater for localised warmth. Once I am moving about I generaly warm up and don't need much.
I was working in the garage a -5 outside last year... TT
Cheers guys - looks like it might be better to invest in some more thermals
I recommend a little devil propane heater, we had one of these in the workshop for the last two years, heats 1000 sq ft in about 1/2 hour if you use a large propane cylinder to get decent gas pressure. I think we paid about £50 in the preowned section in Machine Mart.
http://www.machinemart.co.uk/shop/pr...rkshop-heaters This year we got fed up with the cold and the fume smell from the gas so we got a fixed powrmatic NV, but we are running a business from the premises!
http://www.flickr.com/photos/29404787@N03/ http://www.flickr.com/photos/41021922@N03/ http://www.flickr.com/photos/56936222@N04/ http://www.flickr.com/photos/79486076@N06/ Finished my roadster after 5 years! Number 27! Last edited by Spikehaus : 22nd November 2010 at 11:16 PM. |
I use a cheap 2kw fan heater from argos, cost about a tenner. I put it on for an hour before I want to work in the garage and it makes a world of difference, especially when there is frost on the inside of the walls. If it's really cold I also use a 3 bar halogen heater aimed at where I'm working.
It works well, but last year i found that i had to turn them both off to use the welder, or it stays dark when i lift the mask up!
Check out my Build Blog www.samsv8locost.blogspot.com And here's all my build photo's on a picasa web album http://tinyurl.com/5tbtm46 |
Fan heaters are great if you can insulate your working area. All you really need is a kind of tent, with no leaks, and it will be ok as it heats the air in which you are working.
Yes Mr H quite right. I found my fan heater didn't do much until I hung curtains over the windows and put a draught excluder around the doorway, the difference that made was quite remarkable.
At least at the moment I have an extra blanket of snow on the roof to keep some more heat in ![]()
