Old 11th December 2010, 11:13 PM
i had two diffrent makes of draglink one fitted 3ge mushrooms onne had the a shorter thread!
as for sierra TRE's thay have off set and are handed not sure about the tapper
when i was at the motorfactors (good friends and have used for years) thay told me QH are the only people that still have both the drag links and the maxi joints in thair stock lists
Old 11th December 2010, 11:26 PM
gaz05 gaz05 is offline
I guessed that was the case with the draglinks. Trouble is I spent £50 on these and don't want to waste them. I'll probably rework the mushrooms to fit. As for the Sierra TREs do you know which side I need to order to get the RH threads.
Total cost so far
Materials £3,150
Tools £855
Old 18th December 2010, 09:12 PM
Big Vern Big Vern is offline
Originally Posted by Trophy Blue View Post
It really irritate3s me when they describe RS2000 track rod ends. There is no difference between a 1100L TRE and a RS2000 TRE. As far as I know, all metric TRE's will fit ie. Escort, Cortina, Sierra's all the same tapers, threads etc
As TT says Escort ones don't fit the sierra uprights! They have the same taper but are too short and you won't have the correct angle of movement which you only find out when they break!!
RS2000 Tre's ARE different as some escort racks/struts were imperial and later one's were metric. RS2000 Tre's were a metric/imperial hybrid.
It really irritates me when people post what they think they know rather than factual information. Costs people a lot of time money and frustration to discover this...
BV.
Old 10th January 2011, 06:59 PM
I missed this. If RS2000 TREs fit the Sierra uprights then why don't mine? Is it possible EDS haven't sent RS TREs but standard escort ones. I spoke to the lad in my local Ford dealer recently and he says there is no difference between petrol and diesel uprights so that's not the problem.
Total cost so far
Materials £3,150
Tools £855
