Old 30th December 2010, 08:21 PM
Question Nuts!!!
CP18 needs a 7/16" captive nut. Is that spanner size (which seems a bit small)
or a thread size?And why not metric?
Also was I right in thinking that that the M8 for the roll cage bolts equate to 13mm spanner size ?
Grateful for any help -nearly ready to weld up the chassis - does any one think smooth hammmerite might do a decent paint job( I've got a big tin of it in the shed)
Thanks
Old 30th December 2010, 08:26 PM
fabbyglass
When a drawing states a thread size it means thread not the spanner...so 7\16 it is and m8....depends what fitting used as some jap stuff use small heads and could well be a 12mm across flats spanner
Old 30th December 2010, 08:27 PM
7/16" UNF thread
Motoring indusry stardard thread used in seatbelt bolts ( Exept for most Jap stuff )
Old 30th December 2010, 08:34 PM
David_17's Avatar
David_17 David_17 is offline
Yep, as said 7/16 unf. It's a finer thread than an m8, you'll see the difference when you get them.
*updated 7/6/11*
