Old 25th January 2011, 09:16 PM
Pavel Pavel is offline
Default Front wishbone geometry
Right, I'm still CADing my chassis but have just attached the uprights, wishbones etc. to the chassis.
I get silly camber (over 5 degrees). I can't for the life of me figure out why this is, as I've used book dimensions for everything.
Could somebody confirm the following dimensions (in square brackets are what I've got):
1) From chassis pivot axis of lower front wishbone to centre of lower ball joint [414.50mm]
2) From chassis pivot axis of upper front wishbone to centre of upper ball joint [260mm]
I'm sure I've got the geometry wrong somewhere, but need to narrow it down.
Thanks,
Pavel
Old 25th January 2011, 09:38 PM
On the top wishbone there is a M18x1.5 threaded bush and it has a transit track rod end which is.........?
Old 25th January 2011, 09:47 PM
Sorry, the 260mm is from the wishbone pivot axis (chassis end) to the actual centre of the ball-joint (so takes into account the exposed track rod).
Old 25th January 2011, 10:05 PM
The top ball joint is adjustable by 15mm so will give +/- camber?!
Old 25th January 2011, 10:08 PM
fabbyglass
Are you using Sierra uprights?
Old 25th January 2011, 10:11 PM
Yes, sierra uprights.
Talon, I'm well aware of that - hence why I wanted the distances I requested - if my bottom wishbone distance is fine, then it's the upper track rod that just needs to be extended out slightly. I just wanted to confirm what the distance should be so I can set a point to aim for.
Thanks for both your responses chaps!
