Old 27th January 2011, 01:15 PM
Default clever dick needed (cad or somthing)
i have got as far as finishing the main chassis and am tacking on the wishbone brackets (wisbones already done ready to bolt up)
anyone clever have drawings or somthing to check all the alignments as im a bit paranoid and want not to have to do it again after my build is nearly finished
idealy i would like to be able to check it before the car is been assymbled
i did have an idea to take it to an old work place and get it on a 4 wheel alignment jobbie but i want to make sure my chassis is spot on befor i go on
Old 27th January 2011, 02:13 PM
fabbyglass
There is a drawing in the book for a jig that sets the wishbone brackets...measure, measure and measure then tack them on and measure again.
Old 27th January 2011, 10:53 PM
i was looking at front to back and arm end placement as due to the length of the arms error in bracket hole with width could get multiplyed so the arm ends in are in diff positions if not spot on
was hoping someone may have worked it all out for before
Old 28th January 2011, 07:30 AM
fabbyglass
Lost me there...... but if the holes are wrong on the brackets it throws out all the measurements given in the book.
