Old 28th January 2011, 01:33 PM
carlknight1982's Avatar
Feelin like a teat tho over the driveshafts
Roadster No 2 build
Cost to Date : £93
Old 28th January 2011, 01:34 PM
Originally Posted by carlknight1982 View Post
All I spotted buddy was no lock nuts on your uprights!! Thanks guys
That'll be because they are the plain nuts I am using prior to final assembly !!
Sorry my efforts have not been of any use to you .... Hope you manage to get it sorted.
Old 28th January 2011, 02:00 PM
Know that feeling thanks for your efforts dude
Roadster No 2 build
Cost to Date : £93
Old 28th January 2011, 02:41 PM
fabbyglass
Sorted now?
Old 28th January 2011, 03:46 PM
i'll let you know still if you fancy a day of coffee and biscuits mark your walcome to come help with the rest of the rear brake lines ;~)
Roadster No 2 build
Cost to Date : £93
Old 28th January 2011, 07:17 PM
Abs ring doesn't seem to be removable
Roadster No 2 build
Cost to Date : £93
Old 28th January 2011, 07:48 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, mine all went together fine without removing abs rings or anything else.
makesure the hub is pulled all the way through the bearings you should see a couple of threads sticking through the nut. also make sure the shafts havent popped out of the joints and check the prop flange on the diff is central in the tunnel.
finally when its all together you should be able to move the shafts a little sideways this will show nothings binding
hope this helps
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 28th January 2011, 08:04 PM
fabbyglass
No need to take that off if it's possible to anyway.
