![]() hi
i've got a type 9 gearbox with bell housing, but i seem to be short of the clutch arm. does this come with a complete clutch kit or have i got to find 1 seperate????? the engine i will be using is a 2l zetec with hopefullt a 1.8l fly wheel. what clutch kit do i need and release bearing??? cheers steve |
![]() On my 1.8Zetec im using a standard mondeo clutch kit, but longer release bearing. Will try and find you the part number
http://www.flickr.com/photos/3326151...7611049241239/ |
![]() Part No. CCT113. Its from a capri so that should help your search! Good luck!
![]() is it heavy at the pedal with this pressure plate?
i will be using a 1800 silvertop on a type9 and will be getting to this bit at some point |
![]() I dont find it too bad? Although if you did, then you could always move the cable down the pedal? if you see what I mean?
![]() On a 1.8 flywheel, you need Mondeo 1.8 clutch (220 mm disk, 26mm shaft, 23 splines). As for the clutch release bearing, some people make do with a Sierra bearing (Quinton Hazell CCT132), also I've heard some put on two of those, some get the longer CCT133 bearing. Here's a list of part numbers of equivalents in other catalogs: http://www.haynes.co.uk/forums/showt...?t=4036&page=3
![]() i think you guys are missing something here. he is missing the actual clutch arm not just the release bearing.
the release arm should be with the box you wont get a new one with the clutch and replacements are like rocking horse poo. i would contact the person that sold you the box and ask if they still have it.
My Roadster Is Finished NerNer....... Pigs can fly, you just have to carry them onto the plane. My Pictures http://s707.photobucket.com/user/ashgardiner/profile/ |
![]() True story Ash! They come up occasionally on ebay, maybe keep your eyes peeled, or as Ash says, email the gearbox supplier?
![]() Usually a few on ebay or Burton power used to do them brand new,links below.
http://cgi.ebay.co.uk/Ford-Pinto-Ral...item41565beed5 http://www.burtonpower.com/ |
![]() what starter is everyone useing i got a fiesta zetec 1.8 one and a sierra 1.8 cvh one but the pinion clutch is dead so it will be cash for a recon if the fiesta one is no good
