Old 13th February 2011, 11:32 AM
Default Bolt torque
Hello All.
Can anybody shed a little light on the above, as in a formula for bolt diameter and length versus torque setting for certain bolts.
Old 13th February 2011, 12:16 PM
CaptainCrash1971's Avatar
CaptainCrash1971 CaptainCrash1971 is offline
Try this website and click on the link that says 'try our torque calculator'
It also gives you the basic mathematical formula http://www.rockcrawler.com/techrepor...rque/index.asp
Hope this helps
Alan
Costs so far :- Too much but somehow not quite enough
http://alansroadster.blogspot.com/
Old 13th February 2011, 12:37 PM
mopple mopple is offline
Maximum torque values for metric bolts can be found here http://www.cncexpo.com/MetricBoltTorqueNm.aspx
But value for every bolt is application specific and should be calculated individually.
Old 13th February 2011, 01:47 PM
Ask and ye shall recieve,thanks gentleman.
Old 13th February 2011, 06:43 PM
Some good resources there
Paul
I normally tighten big bolts up until I fart
You could always use my little brothers approach, Tighten them up until they shear, then back them of half a flat
Old 13th February 2011, 06:51 PM
There is always the universal torque setting of "F" tight
Old 13th February 2011, 08:18 PM
Ronnie,I manage that with no effort so there would no indication of torque on the bolt just stress on the waistband
" F" kin tight is too tight Arfon
