Old 22nd February 2011, 10:46 AM
Peter-C Peter-C is offline
Default Am I correct ?
My wiring loom came out of a K reg 1.8 sierra estate. After ages trying to fathom the thing out using a Haynes Manual I decided enough was enough and purchased a bespoke loom. I now discover that the original appears to be from an earlier car - models up to 1987.
Can this be right ?
Peter
Old 22nd February 2011, 12:31 PM
Did you strip the loom out yourself? The Haynes electrical diagrams are awful. They aren't clear at all and take ages to cross reference all the interlinked pages.
Old 22nd February 2011, 12:33 PM
Yes, I stripped it out myself. It just seems like a Friday afternoon job and they fitted what was available. It wasn't until I was checking the relays that something seemed amiss.
Old 22nd February 2011, 01:17 PM
Post up a picture of the door loom connector, or the connectors from the engine loom to main loom.
Will be able to tell you in a second.
Old 22nd February 2011, 02:52 PM
Are these the two plugs that have 4 and 6 wires in them ?
Peter
Old 22nd February 2011, 03:56 PM
If the door loom connectors are blue red and white ( or 2 out of the three ) the that is a >90 loom ( can't remember the early ones off had but think black and white ) also if the ECU loom plugs into 3 black blugs ( 4,8,6 pin) ratehr than a pair of white and green ( 6 and 9 I think ) then it's a >90
Old 1st March 2011, 07:52 PM
The original loom is in bits now so the plugs have gone. I think its an early loom because it has 3 pin flasher unit. Another thing thats confusing is I found a pinout diagram thats contained in this thread
http://www.haynes.co.uk/forums/showthread.php?t=4606
The pin numbers and wire colours on my column switches are as per the drawings but when I look at the Sierra diagrams in the Haynes manual I cannot find all of these numbers.
This is doing my head in !!
Help !!
Peter
Old 1st March 2011, 09:17 PM
I have just had a look through the official diagrams and the HBL
my official Diags don't go back beyond 89 ( lost the early ones ) but the HBL shows a 3 pin flasher up to 87 which is the last of the MK1's and then a 4 pin after 87 MK2.
It seems very implausible that ford would use a 5/6 year old old stock loom.
So how has it got there?
Old 1st March 2011, 09:18 PM
Have you got a picture of the fusebox? MK1/2 are different.
Old 1st March 2011, 11:23 PM
Cheers TT
I'll have a look tomorrow.
Peter
