Old 28th February 2011, 07:24 PM
888sp3 888sp3 is offline
Default Upper wishbone camber adjusters
I'm sure there is a logical engineering reason for this but why is the larger threaded hole in the smaller diameter boss?
Old 28th February 2011, 07:43 PM
Tilly819 Tilly819 is offline
an interesting question, it may be to allow the use of quick adjust camber adjusters such as these
http://www.rallydesign.co.uk/product...cts_id=1 1837
they require a smooth bore in the wishbone then the top ball joint is screwed into the adjuster
if this is not the case i cannot see a reason for the front upper bone boss to be so big since in its the most lightly loaded wishbone on the car
tilly
Old 28th February 2011, 08:01 PM
A good question indeed
I thought it may have something to do with.....being a larger bore & quite a course thread pitch, for each turn of the adjuster it allows the adjusment to be fine tuned without reducing the amount of thread from the drag link from being inside the boss , keeping a secure connection between the connecting parts but still allowing adjustment....
I,m probably way off the mark tho
Old 1st March 2011, 11:00 AM
I have often pondered that same query and as far as i believe there is no logical explanation apart from maybe allowing a bit more room at the top of the upright, in between RU2 plates, but they are away from them anyway. It should be fine to make these from the same 30mm rod as the front adjusters.
Regards...Andrew
Old 1st March 2011, 12:59 PM
Wynand's Avatar
Wynand Wynand is offline
Here are a few pics of the camber adjusters I made on the lathe and installed in the upper front wishbones. I used Cortina uprights.
Wynand
http://5psi.net
Old 1st March 2011, 01:02 PM
They look really nice, much better than the Rally Designs adjuster.
Andrew
