Old 2nd March 2011, 11:14 AM
Default Welding my nuts
I'm about to weld the seat harness nuts to the CP18s.
The nuts I have are BZP - should I grind the zinc coating off before I weld them?
Should these nuts be fully welded all the way round, or just tacked in a few places?
Thanks,
Old 2nd March 2011, 11:24 AM
You want to clean off all coatings on steel before welding, as a general rule. It would be best to fully weld it as its no extra effort, but a massive disaster if the IVA man decides it needs to be fully welded once your car is complete.
Edit: Thinking about it, just a couple of tacks on the lower ones should be sufficient as its just to make fitting easier. The upper ones need fully welding
Old 2nd March 2011, 12:24 PM
misty misty is offline
I welded all the nuts complete just to make sure they dont turn it down it really pays to go the extra mile to make sure
Old 2nd March 2011, 01:17 PM
I guess it probably is worth fully welding them just to be sure.
I was just a bit worried about the threads distorting if I did.
Old 2nd March 2011, 06:24 PM
tkpm tkpm is offline
when i weld nuts on i put a bolt through the nut, which keeps the thread nice a clean from weld splatter.
Terry
Old 2nd March 2011, 06:25 PM
Tilly819 Tilly819 is offline
yes and yes
tilly
Old 2nd March 2011, 07:14 PM
Davey's Avatar
Davey Davey is offline
Never mind Mr IVA's feelings, do you want the seatbelts/harnesses to restrain if/when you get it badly wrong? If you answer yes to this then the only answer is fully welded nuts surely?
D.
Old 2nd March 2011, 07:31 PM
dogwood's Avatar
dogwood dogwood is offline
As already suggested, defo put bolts in before welding,
And yes fully welded
David.
Old 2nd March 2011, 07:44 PM
D.
Surely having a captive nut or not, does not give the bolt any more strength in a collision? The captive nut is simply because trying to do a nut up behind the transmission tunnel is next to impossible. Besides welding the nut must introduce some unwanted heat that could affect the thread strength?
Old 2nd March 2011, 08:07 PM
I think you could safely bet money that you could lift a full car on the seat belt mounts if welded sufficently well,1/2 in weld will allegedly hold a half a ton in weight and I folded my brackets to give more area and welded both sides.
The nut is there to secure the bolt in the hole and there should also be ferrules so the seat belt can move when the bolt is tight and dont forget it's through a 3mm steel plate,my humble opinion, its going nowhere if fabricated with care and attention.
