Old 6th March 2011, 11:02 AM
David_17's Avatar
David_17 David_17 is offline
Default Harness mount bosses
Where's the best place to get some 7/16 threaded tube to weld into the roll bar to mount the harnesses?
*updated 7/6/11*
Old 6th March 2011, 12:33 PM
PM sent to you David
Old 6th March 2011, 12:48 PM
james3004's Avatar
I Got mine From 3ge, but then that doesn't really help does it
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 7th March 2011, 07:40 PM
David_17's Avatar
Thanks guys.
*updated 7/6/11*
Old 5th April 2011, 10:02 PM
ginger nutter ginger nutter is offline
I am in need of some threaded tube for my upper harness mounts been searching but no joy, where are you guys getting them from?
Old 5th April 2011, 10:25 PM
As luck would have it, I recently spent a few days working on my lathe.
I have been utilising some of my surplus materials kicking about.
Just happen to have 4 sets of harness bosses up for grabs
They have been made from 19mm bright round bar & have been bored n threadded with the required 7/16" UNF thread, 50mm in length.
£7.50 per set inclusive of postage.
Drop me a PM if you are interested.
Failing that, try Saturn or Talonmotorsport, I am sure that either of them will be able to help out
Old 6th April 2011, 06:56 AM
Davey's Avatar
Davey Davey is offline
PM sent . I could do with a set.
D.
Old 6th April 2011, 07:20 AM
Pm back at you Davy
Old 6th April 2011, 08:15 AM
gaz05 gaz05 is offline
Do They have to be 7/16 UNF? I'd like to make my own but only have metric taps.
Total cost so far
Materials £3,150
Tools £855
Old 6th April 2011, 09:08 AM
Hi Gaz
Strickly speaking no but they should ideally be threadded with a fine thread & metric fine threadded bolts are a real PITA to get hold of, not to mention expensive.
7/16" UNF bolts have been used for years & has more or less been adopted as the industry standard for seatbelts
If you buy a pair of harnesses new, they will most likely come with 7/16" UNF fixings ( Mine certainly did )
All is not lost mate.
You should be able to pick up a decent 7/16" UNF tap on ebay for not a lot of money
Hope that helps
