Old 5th March 2011, 11:46 PM
les g les g is offline
bonzo
beleive me he is ultra anal i just call him an a@@e
he even has a tool wrap of his "special chisels" in that van of his....
they only ever comeout when he is in the poop etc.
we had some rounded nuts on my fiesta manifold the other day
and the ""special chisels came out"" a couple of dabs and they were loose
then into the van and out he came with new nuts and washers
its like a frigging Tardis
TJ
PS: ask Mighty mouth..
at Stoneleigh he had a snag into the bac k of his van and afew minutes later all sorted
Old 6th March 2011, 12:04 AM
Originally Posted by Eternal View Post
humm hows a spot welding drill work?
its for drilling out spot welds
flatish with a small point so you can drill a spot weld off one sheet of steel and not go trough the one under it
Old 6th March 2011, 12:39 AM
Eternal Eternal is offline
Ahh i see. Cool thanks
Skyline Roadster
Old 6th March 2011, 11:19 AM
Originally Posted by les g View Post
Bonzo
Next time i,m down yours make sure your you have a good wheel on your bench grinder and i,ll show you how easy it is to sharpen a drill straight swop for 1/2/3 of Mrs Bonzo,s finest brews
i bet i can get an old hand like you to master it on your 4th go
hows that for a fair swop
cheers les g
Sound's like a fair deal to me Les
Knowing what kind of work you have to do Les, I can fully understand where you are coming from .... Nothing worse than traveling miles to carry out a repair, just to find out that you don't have the one thing that you need
TJ
If it's any consolation to you, my father was exactly the same ( Aircraft engineer )
As a general rule of thumb, if you needed to use one of his tools, it was a case of .. " Best not even go there "
That said, you only had to ask & he would do the job for you.
It is a real pitty that he passed away just before I started my build, he would have been here every day & would have loved every aspect of the build.
One thing is for sure, I would of had a full alloy body for the build, he was an absolute whiz with the English wheel & all things to do with alloy shaping.
Old 6th March 2011, 02:51 PM
next time i,m down yours make sure your you have a good wheel on your bench grinder and i,ll show you how easy it is to sharpen a drill straight swop for 1/2/3 of Mrs Bonzo,s finest brews
I thought of asking you to put a video on Youtube, but then i found one. Is that how you do it too, Les? http://www.youtube.com/watch?v=pW7kGFcM2sc
Old 6th March 2011, 08:45 PM
Smile Well done Albert
That is a nice video clip Albert
He makes it look dead easy
I am thinking " Now, how hard can that be ? "
Usually, my first mistake
Old 6th March 2011, 09:39 PM
That is for Wood drills mind you. If you are doing metal work it might not be quite as good.
Skyline Roadster
Old 6th March 2011, 09:55 PM
TJ
One thing is for sure, I would of had a full alloy body for the build, he was an absolute whiz with the English wheel & all things to do with alloy shaping. [/quote]
bonzo
you are not wrong there
i was trying to weld up the exhaust on my bike today
when in he walked and after much coo cooing noises and staring at the roof of the garage saying things like damn pigeons have got in again.
and then laughing at his own very old joke
he said it would be better to weld a whole new side in the silencer ,
chop out all that rot.
so i now have a spanking new silencer made from the side of a fridge
all i had to do was make the teas...i,m not daft he just thinks i am..
works every time
TJ
