Old 18th March 2011, 07:20 PM
bertie_bas205's Avatar
bertie_bas205 bertie_bas205 is offline
Originally Posted by Big Vern View Post
I'm going on what I've had experience of rather than many who post on various websites what they've read on other websites.
In order not to waste money on Duff information it's neccesary to confirm what people tell you is what they did not what they heard....
When I ordered a CCT133 what I got was a Capri 1.6 release brg and meant for gearbox with 7/8" x 20 first motion shaft and the smaller first motion cover sleeve, so it didn't fit the type 9. Lengthwise it would have done the job though.
When I helped Ryan do this, http://rvann7.wordpress.com/ we machined a 1.8 zetec flywheel to take the Sierra clutch and all problems were solved and no special parts other than the flywheel. I'd done this before and new it worked. I believe Dave college at RetroFord does the same and I'm pretty sure you can get redrilled flywheels from 105speed as well.
The FWD clutch is 'thinner' and the clutch fork is shorter on what Ford call a 'low lift' system to reduce the bellhousing depth for FWD cars as they were tight on space between the wheels.
I can't say about what MT75 bits work as I've never done Zetec to MT75.
You could try Westfield forums but you must make sure the info comes from someone who's actually done it! or you could end up speending a lot of money.
HTH BV.
Big Vern.....
Sorry to trail this post from the bobwebs but with the 1800 flywheel, sierra clutch etc... What starter did you use??
Bertie.
Old 19th March 2011, 12:04 PM
Coozer's Avatar
Coozer Coozer is offline
Starter on mine with that setup is off a 2L DOHC.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 19th March 2011, 01:09 PM
The 1.8 cvh starter works fine to of which i have a spare one if you would like it, £15 for postage......
Andrew
Old 19th March 2011, 10:35 PM
martin62 martin62 is offline
Default starter
Hi Andy if nobody wants the starter I will take it as I am finding hard one like Hens Teeth.Also could you show me how you modified the ST170 exhaust manifold,the down pipe that turns 90 degrees to the rear.Thanks Aidan
Old 22nd March 2011, 10:14 PM
It's got your name on it Aiden, also sent you over some pics and notes.
Andrew
Old 22nd March 2011, 10:33 PM
Post
Hi Andrew Thanks for the pics will have a go on sat.Aidan
