Old 6th April 2011, 10:25 PM
rapidtornado's Avatar
Just done a bit of research on spring rates for R6 shock... they seem like over kill for Haynes:
03/04 R6 shock is 9.85 kg/mm which converts to ~551lbs
05 R6 shock is 10.98 kg/mm which converts to ~614lbs
But you guys say there are people out there with this set up? What's the ride like? .... don't say 'stiff'
Rapid
Old 6th April 2011, 10:36 PM
Is there any info re spec for shocks for some of the lighter bikes ?. Would the spring rates on these be more suitable?
Adrian
Old 7th April 2011, 12:29 PM
Right well maybe the r1 shock is better suited to haynes then i got a figure from yamaha that gave 7.84 n/ mm maybe ill have to do a vid of the travel i think the front with a new mounting point will be fine with my heavy ish 2.0 ecotec and its box.
Only thing with using them then is the length about 12" eye to eye
Old 7th April 2011, 01:32 PM
SV650 shocks are cheap, soft, and plentiful.
Probably a bit on the long side though - I just happen to have one sitting under my desk at work and it's 13.5 inches between mounting points.
Old 7th April 2011, 05:26 PM
how would 13.5 be too long if people are buying 13" with 1" extensions?
Old 7th April 2011, 05:33 PM
I think it would be ok you might need to move the mounting bracket on the lower wishbone though.
Old 7th April 2011, 09:12 PM
My bad. For some reason I had it in my mind that the shock length was supposed to be about 9 or 10 inches
Must have been thinking of the compressed length...
Old 8th April 2011, 08:01 AM
The book is only a reccomendation its not gospel. But it does say " other shocks can be used but you may have to move the mounting positions"
Old 8th April 2011, 10:01 AM
loony's Avatar
loony loony is offline
This is Locost mentioned before - with R6 shocks
http://www.youtube.com/watch?v=odehGEqqo1k
But - it has different front suspension (shock angle) so... for Haynes Roadster maybe R6 aren't best choice.
I found spring rates for SV650 on other site:
1999 - 2002 SV650 and SV650S have 510 lbs/inch - 9.129 kg/mm shock spring.
2003 - 2008 SV650 and SV650S have 430 lbs/inch - 7.697 kg/mm shock spring.
Lucas
My build thread
Old 8th April 2011, 01:12 PM
I had a pair of 1999 SV650s a few years back (one for road and one for track )
I changed the shock on the track one as it was faaar too soft. Can't believe they made it even softer on later bikes!
