Old 15th April 2011, 07:50 PM
Default Rollcage
Does anybody have any plans or dimensions for a full cage. I fancy a full gae now rather than a roll bar. I have built chassis to suit GRP body and rear tub.
Thanks for your help
Leigh
Old 15th April 2011, 08:30 PM
mikemph mikemph is offline
I have been designing one with a engineering company... to my own design but to meet FIA standards.... a little over kill being 50mm tube 2mm wall but it will be strong. The front legs will be outside the chassis as I am over 6ft and would like to keep the leg room. I haven't finalised how I will have the front hoop attach to the chassis either yet.
Very similar to MK rollcage but will NOT have s bend in front legs of roll hoop.
Not sure on the price exactly yet but I could probably get him to make up more once the design is complete and trial fitted to chassis.
I am expecting around £500
If you are interested I will let you know in the next week what it will cost for sure.
http://m1kemph.wordpress.com<---- build blog clicky
Check us out on facebook. Hamlet Engineering Services limited
Old 15th April 2011, 08:37 PM
Yes keep me in the loop, no pun intended
Old 15th April 2011, 08:45 PM
What do you think of the price..... does that sound reasonable?
I'm not sure what other companies charge... I phone a couple one said £1500 and the other said £800.
Old 15th April 2011, 09:24 PM
Deanno's Avatar
Deanno Deanno is offline
I'm planning to go for a full cage but not meeting FIA spec but mainly for show and general looks it should be safe enough if the wost should happen but the only problem i see with it is the front legs have the curve in it giving it a Weak point.
hope this helps:
http://www.haynes.co.uk/forums/showthread.php?t=4827
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 15th April 2011, 09:57 PM
I cant have s bend if I plan to race it as it will not meet FIA spec..... but fine for a road car
Old 15th April 2011, 10:47 PM
hope this helps:
Looks nce Deanno, commented on the look of your cage b4. What does it need to be made out of? wall thickness etc...?
Old 15th April 2011, 10:49 PM
I like th elook of Deannos cage but would like to turn my hand at hil climbing. What are the guidelines?
Leigh
Old 16th April 2011, 12:06 PM
Deanno's Avatar
Leigh,
its not my cage but its the one i plan to copy,
i agree its not to FIA spec as i am only going for looks but for IVA i'm putting the standard hoop on as this will be used when i eventually put a screen on as i plan to use it as my everyday car.
All the Best
Dean
for hill climbing i would think just a roll over bar?
where abouts are you located? there is a hillclimb in Llys-Y-Fran on the 8th May and 17th June.
Llys y Fran
Clarbeston Road
Haverfordwest
SA63 4RR
Old 16th April 2011, 06:21 PM
Thanks gents, sorry Deanno, got a bit confused there, thought that pic was your cage, I have seen it before.
Deanno
I am in Wrexham so a bit of a trek. I went to a hillclimb near Shrewsbury a week or so ago and it is on again end of the month so will I probably go again.
Mike
The price seems reasonable. It is more than what I would like to pay being a tight arse, but probably a fair price. I was asking for dimensions/plans as I would have a go making my own, havent priced up steel yet, but would imagine it would be alot cheaper than £500.
