Old 16th April 2011, 11:19 PM
trick-kit trick-kit is offline
Default CP Kits, opinions please
Hi fellow forum members,
I've been having a think about how to make things easier to do, i have had a look at the CP plates to begin with and this is what i have come up with. Other parts will be looked at to help help make things easier & reduce costs where ever possible.
The parts that make up the suspension towers, CP3, CP4 etc etc have been designed to key together to make life a bit easier. The shock brackets then slot in and when in place are 19mm away from the edge to correctly locate tube RS15. CP14 is cut to the correct length and I have put a small cut out in it to point out which way up it should go. Other little tweeks here and there have been done too.
So what do we all think?
Cost will be for a full set of plates (CP1 to CP25) including the shock brackets is a very reasonable £75 collected, or if you require it posted £79.99
If you are interested in one of these kits, drop me a PM,
ATB
TK
Old 17th April 2011, 12:04 AM
Airhead's Avatar
Airhead Airhead is offline
That is a very cool idea my friend! Quality products making life easier for the average Joe.
M
Ther's no place like 127.0.0.1
My build diary. http://www.mx5-locost.co.uk
Old 17th April 2011, 12:05 AM
I'd have bought that if I was back at that stage
Thats a good innovation -I particularly like the idiot-proof bracket location
Well done
Regards
Adrian
Old 20th April 2011, 05:36 PM
Ricky Ricky is offline
Red face cp kit options please
Hi I like that idea and would not mind buying a set the only problems is I'm all the way in south africa so if I may ask would there be drawings for this kits or will that not be possible ?
Old 20th April 2011, 07:53 PM
Jimmyd Jimmyd is offline
Brilliant idea!! Too late for me but maybe when I go to on to the 2nd build.
J
Old 21st April 2011, 11:54 AM
There's certainly the posibilty to do that, but there would be conditions obviously
Drop me a PM and we can discuss it
TK
Innovation not Imitation!
Old 21st April 2011, 11:57 AM
Smile CP Kits, opinions please
Yes of course what will those terms and conditions be
Old 21st April 2011, 12:03 PM
Nothing sinister just the usual ones that keep my Intelectual Property Rights safe.
TK
Old 21st April 2011, 12:09 PM
Wink CP Kits, opinions please
Yes of course I understand but its just for personal use not sharing it with the world I believe that respecting a persons ideas and not exploiting it
Old 21st April 2011, 12:40 PM
So if you don't mind to share those drawings you can email it to me if you don't mind my email is rjt.correia@gmail.com
