Do the Roll hoop back stays and cross brace have to be made from CDS?
I will be mounting my seatbelts lower down towords the diff area and not on the cross brace. Anyone got a good site for cutting templates for round rube? Cheers TT
You would be better to mount the belts to the top chassis rail rather than down inside the boot area.
They will be mounted at an appropriate location that does not require protection for MR IVA. Top rail or lower will be worked out at a later date.
My belts have a long single atatchement so I have a lot of variance on where they can go. Cheers TT
No requirement for roll bar so mounts should comply with IVA requirements.
Tubemitre was a program a lot of people have mentioned previous.Dunno if its relevent for what you want though. |
the cros brace will be above shoulder height with the belts running over them. The location point will be elsewhere.
Does the roll bar have to be made out of round bar or can it be made out of 3 pieces of 50 x 50 box tube cut and welded to form the U shape?
Personally I used CDS as I found it easier to source off ebay than ERW that had thick enough walls (3mm+). I got 2.8m for about 30 quid including delivery which didn't seem that bad and would cover the braces and cross section. I would think making it out of 50x50 would be a bad idea as surely the welds wont be strong enough to hold in the event or a roll?
Thats a good point to raise, & easily overlooked,
I,m not sure of the precise wording in the IVA manual but the belts/harness are not supposed to pull directly downwards from the shoulder, as it may be possible in an impact that the force of the impact could break your collar bones . Sounds like TT has this covered tho by having the webbing of the harness running over the top of the roll bar center brace Thats the reason I waited until I had my seats before welding the center brace into position so that I could get the seat/shoulder/brace bar height to the correct position. cheers andy |
Surely having the belt so close to moving parts like the drive shafts is rather dangerous? Ours are fitted to the top rail and are rather expensive willans belts.
