			 I will defo be getting one of these when I get my bodywork, any ideas on price yet?
	My Blog : leroysroadster.wordpress.com  |
			 i will have one of them too
	Finally something i know anything about in order to get the ground effect you will need to break the airflow up by adding a vertical lip to start the air swirling towards the undertray then the fins speed the air up pulling the rear end towards the floor  |
			 Vortex generators,also fitted to aircraft wings !!!!
	Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice.  |
 Cheers...Andrew
	Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH  |
			 I was planning on doing a rear defuser out of carbon fibre.
			any news on prices? alsoSpud you have a PM
	My Blog: deannoshaynesroadster.wordpress.com (under construction) Being overtaken is a sign of weakness. South Wales Kit Car Club www.southwaleskitcarclub.co.uk WWW.HELPFORHEROES.ORG.UK XBox Gamer tag: D34NNO  |
			 I was going to pop in this morning but instead i went to stockton to let real radio smash the wifes ornimental plates
	   lol may pop in later |
			 Will this fit with the rear panel section that was made by Triton? Our car is fitted with the full Triton body panels which we purchased back in 2008, we had a few extras done at the time which Triton intended to put into production but don't think they did so it makes our car rather special.
			#18
			 should have a small effect on the road but the real benefit will always be on track and on motorways and as spud said the rear panel will not act as an airbrake to slow the car down other things you could do is some vents in the top rear of the rear arches to unload the pressure build up in them that will reduce the airbrake effect too so should also help with fuel costs
			#20
