Old 21st April 2011, 11:03 AM
cornishmaid cornishmaid is offline
So will the new panel fit the Triton rear panel?
Our rear panel is a bit different to the production version,we were assured however it fits on in same places and dimensions.
Built February 2009 using Mx5 components.
Old 21st April 2011, 11:14 AM
It should do CM, they are built to fit the same chassis dimensions and it will only need to tuck into the bottom return on the rear panel to fasten to the chassis with the rear panel.
You'll have to put up some pics of your car, it's always good to see other roadsters.
Andrew
Old 21st April 2011, 11:31 AM
Thank you for that, we are in the process of putting a web page together showing off our toys and how we made our car so once it's finalised we will post the link up.
CM
Old 21st April 2011, 01:11 PM
Just been on the phone to Mark who was Triton Products to ask him if anyone else had the modified panels like ours and he said yes there were two done in 2008 and both in Cornwall. He also said that the under panel will fit provided the mould has not been altered as he never altered that section of our rear panel.
We had a long chat about anything and everything, which was always the case while we were building our car.He always had time for a chat and helped with silly mundane things. I asked about his ban and the rumours he was getting back into the Kit Car scene but he just laughed and said yes on the car side of things and wouldn't say anything other than laugh about the other.
So I guess it's a case of watch this space really.
CM
Old 21st April 2011, 01:58 PM
Originally Posted by Eternal View Post
But on a serious note if you do make a window frame scuttle i would buy one. Also do count me in on the rear diffuser for sure.
Me too, on both counts!
Old 21st April 2011, 02:52 PM
You loose out too much having a windscreen fitted to this type of car, the wind buffeting is worse with a windscreen fitted than with simple aero screens. It's also like trying to push a door through the air as the screen tends to be quite upright and acts like a sail.
CM
Old 21st April 2011, 03:51 PM
True, but tell that to my Mrs who's worried about her hair blowing everywhere and getting hit in the face by bugs!
Old 21st April 2011, 03:53 PM
mark mark is offline
Helmet, with a pink mohican on the top.
Old 21st April 2011, 06:49 PM
Eternal Eternal is offline
still i def going the window way as want to get some wet weather gear made up. + with my engine i dont think the window will reduce the power much if anything it will probably help me....
Skyline Roadster
Old 21st April 2011, 07:30 PM
I certainly don't think power will be an issue in yours mate, you may need the extra stopping power!
